Why "daily" systems should not count on impedance rise
sundownz
Pro Seller
Supporting Vendor
I know it is said a 100 times a day... "with impedance rise you are going to be over 1 ohm anyway" when talking about a half ohm load or lower on a daily system.
Sure... if you constantly played individual sine waves one at a time. But, is that what music is?
http://www.audiograph.se/subpages/technical/whatmakesagoodamplifier.htm
"The upper graph illustrates the conventional way of measuring the loudspeaker impedance.
The lower graph illustrates the dynamical approach.
We took a commercial ’off-the shelf’ loudspeaker and did a standard impedance plot for it. We swept the frequency from 20 Hz to 20 kHz, measured the input voltage and current, and calculated the impedance.
However, instead of using a sine wave input signal, we used a square wave. The reason for this is that square waves consist of a large amount of sine waves, as does music. The square wave is of course not an equivalent of music, but for this test it was an easy way of showing that a complex signal (not just a simple sine wave signal) may make the load, from the amplifier point of view, very low.
If you study the graph resulting from the test, you will probably agree that not only is it necessary to check the amplifier’s behavior for resistive, capacitive and inductive loads – the amplifier should also be checked for loads with lower impedance than the nominal impedance of the loudspeaker.
This proves to be very important, since a loudspeaker with a nominal impedance of 4 ohms will sometimes have an actual impedance of 1 ohm or less. The PowerCube helps you perform testing of an amplifier, taking all these load attributes into consideration. "
Keep that in mind when you want to run your amplifier at a super low impedance "daily"
LOL, one too many idiots trying to have warranty claims on amps they ran at .25 ohm?
Nah //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Just taking some time to share good information that most people are not aware of.
got ya, shoot me an IM when you get a break I may need some DB'z for the Statesville show :p
Since Sundowz brings up the issue, I would love to hear his take on low impedence loads period and how it effects things. Like, effciency, longevity, SQ, heat and electrical systems. I see it everyday on this forum, people asking can this or that amp run at .67 or .5 ohms although it is only rated at say 1ohm. Since the manufactuer stated the thread maybe people will listen. So Jake will you answer those questions? Jake at what impedence do you run your own personal gear at on a daily basis?
Would my running .7 ohms (2 fi q d1's) on the saz-1500d be considered "counting on impedance rise" for daily?
0.7 is probably your DC Resistance - your nominal load is 1 ohm which is what the amplifier is made for.
A typical "0.5 nominal" load is 0.35 - 0.4 DCR.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
DBfan187
