Why make a huge port rather than small?
TJD15HC
Why have an overly large port when a normal sized port will still tune the box to the requency that you would like?
What are the benifits? I mean i saw that blue print of that box for like a 12" A or something and it had a 54" port that took up 3/4 of the entire box?
wtf?
Someone help me out cause i dont get it?
Tim:banghead:
The larger port reduces the chance of any port noise.
The port on the eD box is so long because of the small size of the box and the low tuning freq. The smaller box doesn't have a big peak around the tuning freq. like larger boxes tend to have. Results in a much smoother/flatter response, at the expense of some SPL.
If the port area or "opening" is the same, as a box gets smaller the port length must increase to keep the tuning freq. the same.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
985
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
675
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
845
819
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
TJD15HC
TJD15HC
Cambridge Ontario
TJD15HC
    May 12, 2024
Brendon Jenness
    May 11, 2024
