Why invert the subs?
Subs perform best at a certain box size. By inverting the subs, you gain back the box space you lost from the subwoofer's displacement. It's a way of making your box "bigger" without actually making it bigger, I guess
first of all it all depends on your enclosure and sub. in some cases changing it can help, inverting it will change the airspace in the box and ill raise the port tuning. also with the sub firing inward it gets less surface area blocked by the basket but this is all relative to your specifics. the best reason for inverting is when you have multiples, for example 2 subs will have a certain degree of noise cancellation. if one is inverted then this reduces cancellation. its called isobaric.
It really doesn't save much volume or change much of anything -even big subs take up a very small % of the box volume. It's relativity unimportant compared to other factors. However, some subs don't really fit in some places so reversing them can help get them into places they normally wouldn't work it such as a shallow style box that has room in front of it for the motor.
um, just to clarify, isobaric is where you use one driver to "load" the cone of another driver, effectively almost adding the vas, or equivelant air pressure compression of 2 cones to one cone. there are different ways to set it up, like side x side with shared space inverted phase(planar) or firing one at the back of another, but inverting one can allow you to minimize the airspace between the 2, and decrease efficiency loss. one effect of inverting, is that the basket/motor, along with cone shape, can interrupt cone noise, or "sound" wave coming from the front of the cone, and it will operate on mostly air compression waves. and, then there is also the cooling factor. especially with small sealed enclosures, the coil has access to cooler air if played at high levels for extended periods. really, i have not seen, or experienced anyone choosing to invert on these principals, just for the 2 reasons that everyone has already stated. looks, and clearance. sub displacement is also a bit of a factor, but really only makes a little difference on smaller enclosures, and large motors/deep cones. also, to answer your other question about phase, yes, the sub will be moving in the opposite direction, since it will face the opposite direction, so, if you have more than one, the inverted one(s) should be reversed in phase, or there will be cancellation. if it is single, or they are all firing into the enclosure inverted, then phase does not need to change.
right...so um exactly what i said but with the paragraph of bs to confuse a noob...good job.
It'll lower the tuning.
Absolutely. I was thinking the same thing while reading through the thread.
Basically, there were several small positive reasons mentioned and no real, eac negatives. Combine all the positives and maybe together they'll make a big enough difference for you to try it. I ran a setup that way once - with 2x10's, each in their own ported area. I mounted them the "normal" way for a while then later reversed them. The improvement was noticeable.
All other things being equal, improvements will be less noticeable though as the box size increases.
45js45
45js45
lost.....again
akheathen
