Why does my setup ****!! It isnt even loud type r 1500d tcab
lol... i dont ****ing get it lol everyone keeps there eyes out prob will be on ebay this week sometime. It could be the box yes i will email mark or pm him to see what the deal it. I am not sure what he tuned it to sooo. I think 32 or 34 somewheres in there.
my subsonic filter.. I am not sure how in the hell do i ADJ. that there is no adjustment on the amp for it. Well ther is subsonic on or off and since the box is ported i have is on.
There should be a dial near that switch that adjusts it, it will have frequencies on either side much like the LPF, but the numbers will be lower values.
If you box is tuned in the low 30's then the SSF should be set near 30Hz, if it is too high then your amp will not send out frequencies lower then where it is set (say 40Hz...) and your subwoofer will only play when you play tones aboze that setting (like the 50Hz you played....) If you have never adjusted it, then I can guarentee it is in the incorrect position and could be the cause of your lack of output.
wait wait wait. Im still confused on something....when I asked you the other day about your box you said it was great, and worth every penny...which means it isnt the box...period...unless you were lying and didnt even have it hooked up yet and just said it was the shit since it was tcab.
BUT if with your other amp the box pounded...how could it be the box.
on the amp.. There is no adj on the amp there may be one on the HU!
No...
If there is a SSF on the amplifier then there MUST be some way to adjust it, otherwise it is useless to have...
I would suggest turning the SSF off for a minute and play some rap that doesnt reach too low, because you can potentially bottom out the driver. But see if it has more output with the filter turned off.
wtf are u speaking all this shit for kid.
That was back when i just tuned it to where i thought it sounded really good. But when i tested it with the DMM is was like 70-80ish AC volts. Suppost to be at 38-39.
BassBEAST88
06' T.H.S
BassBEAST88
Pa
bikejunkie223
