That wouldnt affect the output of the subwoofer since those settings would be set prior to setting the gain.Maybe u should check the settings on the HU for your sub output
**** YOU PEICE OF SHIT. But anyways ok i now have it tuned to 39.3 everything on HU is off amp is flat and on low on HU sub off bass off on amp everything but subsonic os off freq. In the 60s range. I tuned it with the volume at 30/35 and its barely enough bass to move my mirors now when its on 30 and playing a song and i turn the subwoofer on the HU up to +15 which i only tried once it makes the shit on my rear view mirror jump its so loud. Also makes my pant legs shake..maybe u ****. . .just a thought
Yeah but could that cause it to mess up like described. I did change i got a bigger amp and so far a night mare.. I should go back to the A8000T right now it is better than the 1500D.Did you recently change your setup, cause I asked you not to long ago if you liked your box, and you said it sounded great.....anyways..........
Did you test your RCA's. Not from your radio side, but the end running to your amps....see if they are bad RCA's...make sure all your RCA connections are in tight.....that happened to an install I did recently. I checked everything like 5 times, and it just ended up being that one of the RCA's was not pressed down hard enough, and that did the trick.
No i am not a ****ing idiot my setup is just ****ed up just like you.I am thinking you are just an idiot....
= Teh proofNo i am not a ****ing idiot my setup is just ****ed up just like you.
