myjaja
Audioque
Why does everyone hate them? Why is not good to have a cap? It's better than nothing, isn't it?
A cap will only help voltage fluxuation with dynamic draw. Basically it is used to give amps a flat votlage so the alternator keeps up.So, a capacitor won't even help out on the tiniest thing? Then should I disconnect mine?
Beat you to it....you have more detail though. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifsee people don't understand the purpose os stiffening capacitors. i'll explain it basically for you.
a cap is more or less suppose to be used for sq and not to fix electrical problems. basically is stores up current to release at a split second and only for a second, and then it recharges. so you need a good electrical system to keep it charged. where it becomes useful is on quick bass hits where you amp needs a quick amount of current to keep up, the cap can feed it quicker then the alt can, so you won't have a muddy note. then when the alt can catch up it recharges the cap. an alt only puts out the current it needs to keep everything running, so if your amp is drawing 100 amps, and then a big bass note makes the amp draw 150, the alt is gonna be a second or 2 slow to deliver that extra current where as a cap can release it instantly, and you have a smooth bass note. the cap is being used when the alt is not big enough to handle an amplifier which is not its use
i prolly started typing before you though //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifBeat you to it....you have more detail though. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Indeed couldn't have said it better myself.....see people don't understand the purpose os stiffening capacitors. i'll explain it basically for you.
what the hell is your point?The capacitor issue is never ending. The only people that really understand what a capacitor does is people with electronics backround/experience that are able to
diagnose a problem, then they are able to fix the problem.
If the situation calls for a capacitor, it may help solve a problem, but not
guaranteed as every situation is different. Making generic statements on 'theory
of operation' won't guarantee results.
* Do you take medicine when you aren't diagnosed with an illness?
* Do you tell people to stop eating pizza because you *will* get fat ?
The first step is to diagnose a problem.
The second step is to make a list of possible solutions and try them out.
Hypothetical.
Your lights are dimming on bass notes. What can you do to minimize this?
You need to look at the patient in detail to see if there is an install problem.
If the install is good, then you need to look deeper and see if the capacitor
can help you. Do you know the best way to install the capacitor for your
particular install to optimize it's performance? If you don't know how to
troubleshoot/solve a problem, you may have problems executing the plan.
Do you have bass note SQ problems? How did you measure this problem?
Did you 'bench test' your amplifier in your car with the lowest rated impedance
and check it's output power level with a 'stiff' power source vs 'sagging' power
source ? What is the delta in power? Is it audible if different? Will a capacitor
make the delta less? Did you install the cap and redo the test to make sure it
helps ?
etc.
LOL he just talks until people think he's smart..... //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifwhat the hell is your point?
