Why do we refridgerate batteries??
My only guess would be that because every battery is nothing more than a chemical reaction, over time the battery will eventually run itself out - this happens when you don't float charge a lead acid battery for a few months, it'll just die out and not be able to take a charge anymore. Dropping the temperature might slow the rate of reaction down, so more of the reactants hang around instead of being used up.
Just an idea.
SiteHostedOnYahoo said:
Putting batteries in the freezer or refrigerator doesn't prolong their life
Alkaline batteries stored at "room temperature" self discharge at a rate of less than two percent per year. So normally refrigerating or freezing them will only help maintain their charge by a tiny amount. Hardly worth the effort of chilling them. However, if alkaline batteries are stored at higher temperatures they will start to lose capacity much quicker. At 85 degrees F they only lose about 5% per year, but at 100 degrees they lose 25% per year. So if you live in a very hot climate or are storing your batteries in a very hot location, it may be worthwhile for you to store your alkaline batteries in a refrigerator instead.
NiMH and NiCd batteries self discharge at a MUCH faster rate than alkaline batteries. In fact, at "room temperature" (about 70 degrees F) NiMH and NiCD batteries will self discharge a few percent PER DAY. Storing them at lower temperatures will slow their self discharge rate dramatically. NiMH batteries stored at freezing will retain over 90% of their charge for full month. So it might make sense to store them in a freezer. If you do, it's best to bring them back to room temperature before using them. Even if you don't freeze your NiMH batteries after charging them, you should store them in a cool place to minimize their self discharge.
Weird.
Its slows down the deterioration of the battery.
But..
It has been tested and shown that putting disposable household battery's in the freezer makes a negligible difference in shelf life.
However it has been proven that automotive battery's have a longer service life in colder climates such as Canada by as much as 2 years.
azbass
the salty ca.com mod
azbass
Long Beach, CA
Black_Jesus
vegang
vegang
