Why are my speakers distorting?
turn gain to zero, turn volume to 75%, turn gain up slowly untill you detect distortion, once you do back up gain a smidge untill no distortion at 75% volume.....not very technical but easy decent way to set gain. There are better methods, but I'm guessing you don't wanna calculate voltages.
if you say "Ground the RCA" it doesn't tell someone what to do. ground what? the center pin??? that would be a bad idea.
that's why I clarified how to do it. the purpose of grounding the shield on one RCA is to verify if something inside the deck (ahem, Pioneer) has failed resulting in noise due to a lack of continuity to reference ground. Really, it's just a Pioneer fix because of their silly diode. And since all RCA shields are internally tied to signal ground (not always chassis ground, and does not apply to balanced two-wire systems) then you only need to do one shield.
in the future, don't say "ground the RCA" since it isn't telling the whole story and someone could damage their gear trying it improperly. instead, provide proper advice by suggesting they "ground the shield of one RCA at the head unit). details are important when giving advice.
sounded to me like you wanted him to ground the shielding
thanks for the quick advice on amp gains. as for grounding the rcas, they werent an issue.
Are pioneer HU that bad? ive been debating on switching to an alpine, not aware of other companies that make decent ones. havent done my research.
Alpine is decent. I actually like Pioneer Premiums they are pretty nice. Panosonic's entry level ones come cheap with all the necessary features/ LPF/HPF/3 preamp outs, Aux input and costomizable EQ for like 100$
that's the point. the shield on the RCA is what you need to ground. an equal solution is to ground the outer rca jack on the HU. when the pioneer diode "pico fuse" pops from someone messing with RCA's while the HU is on, you lose continuity between ground and the RCA shield. as a result, the amp receives a "floating" input which results in a potential difference between HU ground and amp ground.
what do you think "grounding the rca" entails and why you do it?
you never ground the center pin, that has the audio signal and could damage the HU output. if the center pin becomes grounded, the output won't work. that's why you measure your RCA continuity before you install them. measure along the length for both pin and shield, and measure between pin and shield to ensure there isn't a short. some come from the factory with a short. poor quality control. you only need to install a couple bad RCA's before you test them first.
Dirtrider4eva
√\_The CaUsE__
Dirtrider4eva
Milwaukee, WI
keep_hope_alive
BP1Fanatic
BP1Fanatic
