Who's runnin' their Eclipse 8455 active?
Hoot
I have a CD8455 as a source for my CDT Eurosport braxials. Right now, I am using the Z-series crossovers on them. I want to consider running active.
Does this make sense only if I go w/a three-way stage? Also, I plan on adding the Upstage/Stagefront system to my A-pillars... not sure if this is really possible if I were to go active.
Anybody experience a similar situation?
Hey, fellas, I realize all of the above... I guess I am wondering how to go about this if I am running only a two-way set plus sub. In pro-mode, we are really talking a 4-way setup when including the sub (= three-way + sub). Right now, I have only braxials (two-way) plus the sub -- see what I am getting at? Not sure how I would likely best utilize the dsp if running active.
Also, since I guess I really tossed out a two-part question, the issue also includes the the implementation of the Stagefront system off an active setup -- here, I guess I just run the blending modules following the amp and split the two tweeters with it?
Fantastic, then how about some advice for how not to blow my drivers - I just haven't done it before. Do you just set the crossover frequencies on the HU and then wire things up? I mean how do you tune things? Sure, I know how to manipulate the settings, but how does one do this both strategically and safely at the same time? I assume things are set and then forgot - can settings be locked for safety? Otherwise, one mistaken move with the dsp button and pow....
yes , more power, more control, more dynamics, more volume! Go for it!
I am running a 1996 Reference Picasso, bridged. Bridged, the amp is rated for 2 x 100 RMS at 12v; Four-channel mode the amp is said to give 25 x 4 RMS at 12v. Still think active is the way to go? I suspect it is... I am just curious to hear the justification for as to why. Thanks for any thoughts.
Hoot
Hoot
Champaign, IL
Hoot
ThxOne
    May 13, 2026
