who has owned an ED product before?
paikiah
Wangaholic
Could be before, or currently i use.
If you could be kind enough to mention
model:
when you had it:
ported of sealed:
advantage:
disadvantage:
quick overall impression:
if you don't mind, I'd like to ask a few question via pm... you could always say no and i'll pass. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks a lot guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah model:
when you had it:
ported of sealed:
advantage:
disadvantage:
1. 2 e12k's...2003(obviously not flat cone...logo on front)
2. I currently have them
3. Ported, 2.5 cubes each @32hz
4. They are quite possibly the best sub in their price range. Have a nice mix of SQ/SPL...my boxs maintains good SQ and is **** loud. Great quality, run by a jbl600.1
5. NoThInG...
6.I am impressed with the quality and performance of these subs for their price. I can definetly say they will blow away any peeps in my town, plus i saved a lot of money!
Sure, go ahead an PM me if u need to. peace
NG
model: K series (logo on front)
when you had it: used for a month out right now due to construction of new enclousure.
ported of sealed: sealed
advantage: good blend of spl and sq
disadvantage: none i can think of
quick overall impression: overall sweet sub love it recommend ed products to everyone
model: e10kd2
when you had it: sill have it, though not in use anymore
advantage: Clean sound, accurate response. Pretty good low end for a 10", basically a pretty well rounded sub for the price.
disadvantage: hmmmm.
quick overall impression: Very nice sub. Outperforms the others in its price range...
model:
when you had it:
ported of sealed:
advantage:
disadvantage:
I had 2 15" elemental Designs K-series subs 4-ohm
I had then in a 6.0ft3 ported enclosure tuned to 38hz...THe subs did extremely well in the ported box..even at upper power and volume levels still maintained a stimulating mix of SPL and SQ..Actually the SPL was so great, it would blur your vision and it knocked one of my mirrors off of my stang...
I think the advantage of this sub, is not only the price..which for an SQL sub u cant beat the price for this sub..and personally there is no other sub in its price range that can exert the same power/SPL and or SQ levels that the EDk 15's can do..Also the advantage is they do extremely well in small ported and or sealed applications...The basket design and frame of the woofer..helps to give it a good cooling technique..which if u play continuous bass at a little over RMS..You can really see where these are advantages...Also the VC terminals are nice..they lock-down terminals as I call them..Unlike a lot of JL's and other cheaply built woofers that have the Push-on VC terminals..These are a lot easier to use, and dont require sizing anything up or exerting yourself in order to hood the sub up!!
The only disadvantage I noticed was that they dont make the 15" ed k's anymore //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...To be quite honest with you, I really cant find any disadvantages with the EDk;s..I loved these subs..They never gave me the first problem..Not to mention they held up well in a competition enviroment as I call it..Running tones on them at upper power levels still maintained to work decent even though they are built more so for SQ..I rule them as a great SQL sub....The only disadvantage I would say is that the SQ isnt as good as I as assuming it would be..But then again its in a ported application..and it was rather nice for ported..so I wont say that one
Q quick oversight of the woofer is that they are a great SQL sub..the initial price of the woofer wont drain your bank account..and u great a good dose of SPL/SQ for the price..almost matches that of some $400 woofers..such as the JLw6v2, Eclipse TI's, Audiobahn woofers....The sub can be run in rather small ported and or sealed applications...I would say from personal experience a good box size would be from 1.2-2.4 for sealed applications and about 1.8-3.2 for ported applications...They wont loose any amount of SQ even at upper power and or volume levels..Distortion is also rather hard to obtain with these drivers...These woofers arent designed to be an NSPL or Db drag class winner..But they can sure hold u in the top 5 of certain lower classes...
I would recommend these subs for anyone who likes a w6v2 or any SQL sub....Not to mention if u want to compete in lower class's of NSPL or DB drag or even MECA..Also if u dont want to drain your account, and may not have a lot of space to put subs..I would most definately go with these subs..
I have hit 144 on lin x with these subs..that is with glitches and having to turn amp and HU down because of problems..So they are a very powerful sub!! Dont let an SPL hz chart fool u..with the box I had..It was saying my max was going to be 138.6dbs..geeeshh how wrong was it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif..
On another personal note...I have had a people starring at my car from 1/4 of a mile away..and also had people jump up and look while they were mowing their yards or running a weed eater..yes they are a killer SQL sub for the money!!
Blake
model: e15kd2 (1)
when you had it: current subwoofer
ported of sealed: had it in both types of enclosures
advantage: very versitile sub. Works well with low amounts of power.
Priced nice!
disadvantage: it's not an e15a!!! :p I haven't had any negative experiences
with this subwoofer.
quick overall impression: love the sub! Very clean sounding.
Works well in many different applications.
(high or low power, ported or sealed)
Originally posted by jlaine I own a 12a, toyed with just about every model that's rolled out though.
You got the prototype from eD for evaluation purposes, right?
I've read your opinions on eD's site. I don't kow if you're willing to mention names, but if you could, what would you compare
1. O series
2. A series
btw, bump
Originally posted by RangerMan Paikiah, what are you looking for, SPL? or SQ?
actually, I'm not "buying" anything as such. I'm currently contacting Ben Milne about some corporate stuff, and wanted to know what real users thought of their equipments.
I'm sure it would be awesome, but I still need feedback for investors to see.
I'm at home during the weekends, and trying to sort more stuff out with some personal business, so I can only pm each and everyone that replied to my post on monday morning...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Originally posted by paikiah actually, I'm not "buying" anything as such. I'm currently contacting Ben Milne about some corporate stuff, and wanted to know what real users thought of their equipments.
Hey man, hit me up on AIM;)
Originally posted by RangerMan Hey man, hit me up on AIM;)
rangerman, I'd LOVe to talk ot you on AIM but the darn thing keeps crashing my PC...
I've got one isntalled on the work computer, but at home as well as work, I've got MSN messenger. DO you happen to have that?
Im guessing you're close with the people of ED (team industry) and it'd be great to ask you some things about ED as well as some technical aspects of their stuff.
But I am hoever, a little bit discouraged at this moment, cause Ben wrote somewhere in this forum, saying that there's bit of a problem with paperwork from Korea (i guess that's me)... problem? The last time I replied to his answers, I was flying high in the sky, but now I'm depressed...
paikiah
Wangaholic
paikiah
Seoul, Korea
paikiah
