White Noise Problem
Geezerpoop
Today I put the kicker amp in for my subs, and moved the eclipse amp from my subs to my front stage. There is white noise coming from the speakers when the head unit is on. It is always the same volume, even if the volume is at 0. The rear speakers were taken out, and the RCA's for the back speakers are still connected to the head unit while just dangling in the trunk. I did not have this problem with the 4 channel amp that was hooked up to all 4 speakers before. The head unit was not disconnected or taken out for any reason. I have searched on this topic but have not found exactly what causes it. If anyone has any ideas let me know, thanks.
White or pink noise? j/k
My guess would be poor ground. Do you have separate grounds for each amp, or are they shared by a distro block or simply stacked on top of each other?
I had the exact same symptoms when I hooked up my comps, and it didn't do it when just my sub amp was hooked up. If you wrap some wire around your RCA connectors and ground it to the HU it should solve the problem.
they each have their own ground, and yes one is kind of on top of the other, one is on an amp rack and then one is below it on the ground screwed into the bottom of the trunk
I just installed my DLS A7 and Rainbow Germs with the stock HU, and am having the exact same problem. It exists even when the volume is at 0, stays pretty much the same level, and is there even when the car is turned off. As for the gains, they're way below optimum voltage setting, and the noise only goes away when they're turned all the way down.
I would think if anything, there's your problem. You ideally want a shared ground, that way your odds of path resistance are much lower.
Use a DMM to test your ground. Run one lead to the negative battery terminal using an extra wire, and use the other lead on the ground. Set the DMM to resistance (ohms) and see what resistance you get. You really shouldn't have anything above .5 ohms. If so, test the subwoofer amp's ground (the one you used previously).
If neither of them have a low resistance, find a new grounding location using the DMM. If none of the above is the case, I'd say its in the rca's but definately not restricted to them.
Geezerpoop
Geezerpoop
Northern VA
Geezerpoop
