White noise (hiss) with LOC.
  • Thread starter cwzilly
  • Replies 0
  • Views 1K
cwzilly
Hates distortion
I have a Line Output Converter that I use to connect my amplifier(s) with RCA. Its a Maxxsonics MX-1, not one of those cheap plastic models.
From volume 0 (no music sound) to as high as I wish to go I get a constant "hissing" noise, or also called white noise (much like the noise you get on a blank local TV channel). This is a big let down, because this is why I installed the LOC in the first place, to use RCA cables.
Is this normal for LOCs? JL Audio CleanSweep, AudioControl, Phoenix Gold... ?
I unplugged my RCA cables, and the noise goes away.
I re-grounded my LOC to the headunit ground. No better.
Sadly, the hiss sounds the same, or even worse, than when high had my speaker level inputs connected directly to the amplifier.
And on a final thought, the LOC I am using is: Maxxsonic MX-1; could it be that the MX-1 just is not that good (I can't find any reviews)?
cwzilly
Hates distortion
cwzilly
Where I'm sent
cwzilly
michigan born
    May 14, 2026
michigan born
    May 14, 2026
