which would get louder?
liftedcj7on44s
NC
out of the subs i am listing which would get louder in the proper enclosure with 2500- 3000 kw?
DD-9515
AQ-HDC3-15
TC-5200, if i can find one
or is there anything that can get louder than all of the above?
I am moving on from my IDMAX and now i need to get rediculously loud while staying under 7 cu, ft
your mom.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
nah man i vote for a DD in the correct enclosure
six pack of funky pups //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
good for at least 200 deebees //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
all jokes aside. which one on 3kw? all subs in correct ported enclosure tuned very low, like 28hz, amp will be a saz-3000d
I don't think tuning any of those subs down to 28 hz will get them to reach their max potential loudness. I vote the DD 9515 in 4 cubes net tuned to 36 - 40 hz.
only reason for tuning low is i listen to alot of low bass alot and play alot of bass cd's and i dont want to kill anything playing below tuning, and just anything below 30 makes my little weiner hard!
What you should do is save yourself some money and design a single reflex bandpass for a more efficient pair of 12 inch drivers...Stable accurate and Seriously Loud when you can design your Gain into the box design.Also no 3000 watt amp is necessary after this.The gain possible from a properly designed bandpass Destroys a ported boxes 3db of gain.They are just hard to design sometime.
Good luck man!
Otherwise do the DD's ...Old school tried and proven.
sounds like a personal problem //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
ok so 2 9515's. 2 sundown 3000d's would fit the bill then. tune to 32hz. so to make things fit but not sacrafice output should i do 7 cubes for 2 15's or can i got a little bit smalle?
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
liftedcj7on44s
liftedcj7on44s
NC
BUMPING150S
    Jun 1, 2024
    May 31, 2024
