which wires?
Knukonceptz, Streetwires, Sky High wires, Rockford Fosgate, or Stinger all have some pretty nice wires. Are you asking what you will need to hook everything up?
yes, like which gauge wires and etc. lol sorry for the questions. im a noob when it comes to audio.
If it's a 500 watt amp then you'll only need 8 gauge. Chances are you can only fit 8 gauge in there anyways. You could probably throw your own kit together and save money, you'll need:
Power wire: Knu cca is priced really good and they ship fast. I'd buy of their website. There's really no need for ofc wire unless you're looking to push 6k up.
RCA's: Look around online, sonic has some cheap ones for like $6 i believe. I use the NVX ones off sonic, $15 and work great
Ring terminals: Look around again, get the ones for your gauge wire.
Fuse/Fuse holder: Probably get away with a 50a fuse if you're pushing 500w.
Speaker wire/Rem turn on: Get 16 gauge, no need for 12. Buy about 15ft extra besides what you need for your subs because you have to run a 12v turn on from the head unit to your amp.
If there's one area to not skimp on to save money its electrical. Go cheap and itll bite you in the ***.
you also need a remote turn on wire which is very thin probably around 16 gauge. You can buy a whole 4 gauge kit that will have everything including the fuse that you will need to hook up no more than 12" from your battery
just to clarify this will work the the w3s, and the p500-2? just want to make sure 100% that it will work before i buy it.
It will work just fine for your amp,and any future amp you intend to install.You will need some 12 ga wiring for your subs that is not in the kit.Id prob go with Sky High speaker wiring for the subs
bhodoan
bhodoan
South Jersey
cthedinger
