Which will sound better?
cfox10
Rock the house.
A single set of midbass drivers around 60hz and up on 100w rms, or two on 50w rms each with my crossover a little lower around 45hz. Which will give more output?
I'm asking because if I give rated power to my current polks, I have to up the crossover a lot. If I have them running on a lower rated amp, I can up the xover but output is weak.
I want as much midbass as I can without compromising on SQ
single better midbass per side gets my vote...
Can I ask why? Just curious. Which midbass drivers get low with some power without distorting? I'm tired of having to crossover so high. I heard CDT get pretty low with power.
Cross your subs higher and use a single mid bass driver per side.
My subs are tuned around 32hz, and they hate playing higher notes. I'm looking at either new subs or new midbass drivers, and at this point new midbass drivers would be cheaper unless I want to make a new box and see if my subs do well on the higher notes... then I'd be dropping off a lot on my lowend notes. It's in a truck so no room for 4th order or anything tricky.
Well my only complaint with my CDT's was that I had to cross them so high. I had to cross them around 100hz or so, granted I was running about 100w per side. Now I'm running Crescendo mids crossed at 70hz w/ ~120w per side.
Experimentation is key here. No one knows what that sound is in your head that you are looking for. The more you play around with things, the more you will find what you like. Go with one setup, and then in 6 months or so go with the other one. See which you like better, and run with it.
And definitely cross your mids higher than 45Hz. 80Hz is a decent starting point. Some people prefer 100Hz, some people like 70Hz. When it comes to that, it's a lot about your install and how well your sub will blend with your mids at a certain frequency. Again, play around with it, the outcome will be better to your ears than something someone here will suggest, more than likely.
in order to get good response down to 40Hz, I had to fully seal my door and also fill it with PVC encased fiberglass batt. midbass response requires good isolation of the rear wave. i wouldn't hassle with two - you'll have comb filtering issues as frequency increases and it's much more complex to build well. the time and effort is better spent on one set of nice midbass woofers, and the install required.
This is the proper answer.
Then you have designed an enclosure that falsely eliminates frequency response by losing output before your mids can take charge. You should not be using midbass drivers to produce the sound between 45-60hz. That is a "sub" range.
All that junk on that back wall has been history for awhile now.years lol.i dynamatted pretty much the whole cab cept the roof and if you at least...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
787
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
765
cfox10
Rock the house.
cfox10
Tillamook, Oregon
cfox10
    May 12, 2024
Brendon Jenness
    May 11, 2024
