Which will be have more SPL?
A car's engine displacement is determined by both the bore AND the stroke. A 327 Chevy, and a 350 Chevy have the SAME bore, but...the 350 has a longer stroke. The displacement of a woofer is no different. The average 12" sub's displacement is limited by stroke. The Boston SPG555 has 3.75" of stroke. That's nealy four times the average stroke of a 12" sub, AND it fits in a 1 cft sealed box!! It takes 1000 watts continuous, and sounds AWESOME! You want some serius output? Use two of them in place of two 15's. They will fit in 2 cft of sealed space, and will weigh 52 lbs for two of them without the enclosure!!
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif a 327 can run circles around a 350, as it rev's higher...but I don't really see your point....so your say a Boston have almost 4" of stroke peak to peak?
if we were comparing ported to ported, then the cone area example would prove true.
this is not the case. 2 15 comps in a sealed box would not be louder than 1 15 cvx in a properly done ported box. IMO.
The cone area theory is generaly true. The more the better. But def not in this case. I properly ported CVX with 1000+ watts will stromp all over those lil Comp's and never look back.
yea I misread, thought he was comparing solobaric's and the cvx because they are basicaly the same woofer
Irokpolo
Irokpolo
Apopka, Fl
luvinthebass
