Which way is better?
Boe Jengels
I will soon have 2 s15l7's and am looking at a power acoustiks a3000db. I am wondering if i should wire the subs in parallel or series. I like series but with electricity "following the path of least resistance" i don't know if more power will go to one sub rather than the other.
If they are wired in series, the current will flow through both of them the same. The voltage drop across each one might be a little different because of inconsistencies in the coils, but the current will be the same. That said you will be better off wiring them in parallel. It's only a little extra trouble but saves you from intermodulation between the drivers.
Boe Jengels
Boe Jengels
Bemidji, MN
helotaxi
