Which sundown woofer setup?
AcuraTL
Burnaby
Looking for the loudest setup possible for my car. My max dimensions are 34l x16h x 18d. I've narrowed it down to 3 setups on similar power and all the box will be custom made.
1 12" sundown x running off sundown 1500d
1 15" sundown sa running off sundown 1000d
2 12" sundown sa running off sundown 1500d
dont think you will have enough port area for the 2 12's or single 15. single 12 would be way to go... why not do a 2 sa 10's? i run those is similar box size
yeah I'm thinking about 2 sundown SA 10s. Would you know if that box I posted earlier would be good for a 12 sundown X? It says its made to spec and made just for the sundown X
And is port area excluded from your net volume inside?
Went to my car shop today and got everything measured and these are the setup I'm thinking of running so please have some input on which you think I'll get the most out of.
2 10" Sundown SA 1.5 per chamber at 32 hertz running off Sundown 1500D
1 12" Sundown X 2.5 net at 32 hertz running off Sundown 1500D
2 12" JL Audio W6 1.3-1.5 per chamber at 32 hertz running of JL Audio HD 1200/1
2 10" JL Audio W7 1.5 per chamber at 32 hertz running of JL Audio HD 1200/1 OR RF T1500BDCP
i would do the SA 10's... plan on getting an xtra battery and big 3 upgrade for that amp also.. what do you have for deck mids/highs and wiring??
498
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
AcuraTL
AcuraTL
Burnaby
AcuraTL
audiobaun
    May 19, 2024
    May 19, 2024
