Ffej
Picked an amp, now I need advice on subs. Thanks in advance.
Number of subs preferred: 2
Size preferred (if configuration allows): 12"
Budget: $500ish
Power to be used (which amp(s), include which resistance): Hertz HDP-1 Mono 1,000 watts @ 2 ohms
Space available (take measurements, do not guess): 4'x4'x3'
Goals: low Hz, clean, hard hitting bass
Listening habits: bass head -- Techmaster PEB, Bass 305, Bassnectar, etc.
Preferred brands/subs/whatever: under the impression I need 4 ohm if I use svc's
found a formula that recommends a pair of 333 (min.) to 666 (max) watt subs for this amp-guessing 500 watts is ideal-accurate?
Budget: $500ish
