Which subs
Plus its kinda funny the Cresendo supposedly does 4000 rms yet it only has one power and one ground input where the AudioQue and Sundown have 2 power and 2 ground.
that is at .5 ohm its the identical amp of saz-3000d, you realize most amps come from same buildhouses and from their you pay for whatever the company puts in on testing when they recieve them, overhead, and warranty, crescendo is a brand new company that just came out that is using the zenon board same as saz-3k atomic 3k but they are warrantying the amp at .5 ohm
uh, no...you are very misinformed. Stetsom has 14ks with ONE ground and power input. and it does a true 14k watts easily
4 ohm power @ 13.8V @ .3% THD 855w
2 ohm power @ 13.8V @ .3% THD 1650w
1 ohm power @ 13.8V @ .3% THD 3,370w
.5 ohm power @ 13.8V @ .5% THD 4,030w
65.8 volts
49.2 Amps
1.33 ohm calculated rise from 0.6 ohm DCR **
3237 Watts
14.4 volts rest dropping to 10.75 volts
saz 3k measurments at 1 ohm
http://www.caraudioclassifieds.org/forum/showthread.php?t=6670
internals of saz
http://www.crescendoaudio.com/product.php?productid=17515&cat=249&bestseller=Y
look at the internals of crescendo
about same, same amp, you pay 4 name etc. ask db-r he deals with all these zenon amps
i JUST sold my AQ cuz of a spider problem and bought a DC LV5.. the Hdc3 was as loud to my ear as my 9515G was on 3k.. granted thats what gave my AQ the spider problem.. amp-wise I was set on a AQ 3500D but happened across a SAZ3000D locally and i have been in love ever since.. Sundown is FTW.. but if I were buying and paying for a NEW amp, then i couldnt pas up the AQ.. If used is not an issue (or price) then i urge you to grab a Sundown
DylanH
DylanH
Iowa
abrhino
AJ (ACE)
    Jun 28, 2026
