Which subs are the best for the $$$
If I go with the GPs which model should I get they are available in DVC 2 ohm or 4 ohm
I was thinking about these amps:
Crunch GVP2000.1
RMS: 1000 watts x 1 @ 2ohms
or the
Crunch P1800.4
RMS 450x2 @ 4ohms
The P1800.4 is about $50 cheaper and for basically the same power. Would I be able to wire up either up these sub models and make them able to fit these 2 ohm or 4 ohm load configurations?
Thanks for all the help guys. I'm in finals week and can't look up all this technical stuff on my own right now.
you would probaly do better getting 2 middle price subs than 1 high priced, generally ive seen that 12's are 12's and theres only so much you can do with them, i had the fi q 18 and it knocked out 2 12's easily, but then again it depends on the 12's you get, i know theres combinations of 2 12's out there that will blow 18's out of the water, i watched a video of some guy with 4 12 ssa icons and them *****es pushed some air now, i aint gunna lie, watch that vid
tr10av
tr10av
Miami, FL
dennit469
