Which subs are the best for the $$$
tr10av
All subs are 10". Looking for something relatively inexpensive and a decent SQ but can get real loud when need be.
EDIT:
I've decided to go with the GPs
(2) Crunch GroundPounders: http://cgi.ebay.com/2-CRUNCH-GROUND-POUNDER-10-2000-WATT-CAR-SUBWOOFERS_W0QQitemZ230339773540QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item35a1520464&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
What amp should I be using and how can I wire them?
This is what I was thinking:
If I go with the GPs which model should I get they are available in DVC 2 ohm or 4 ohm
I was thinking about these amps:
Crunch GVP2000.1
RMS: 1000 watts x 1 @ 2ohms
or the
Crunch P1800.4
RMS 450x2 @ 4ohms
The P1800.4 is about $50 cheaper and for basically the same power. Would I be able to wire up either up these sub models and make them able to fit these 2 ohm or 4 ohm load configurations?
Thanks for all the help guys. I'm in finals week and can't look up all this technical stuff on my own right now.
I want to put the subs in a sealed box due to space limitations and I see that DD only recommends using ported. Is that a problem?
Also where can I find these FI q subs?
And would it be better to get 2 cheaper subs or 1 more expensive sub? What kind of difference would it be?
I think the DD are completely out of my price range. I'll never be able to afford an amp to power one of those and I don't have enough space to build a quality box for it.
I think I'm leaning towards these Crunch GroundPounders:
They are dual coil 4ohms w/ 500 W RMS
So if I got 2 of them what amp would you recommend. I'd like to stay with Crunch just to keep all the brands the same. And I'd be putting these in a sealed enclosure. How big would you recommend?
tr10av
tr10av
Miami, FL
dennit469
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
