which sub?
jamie vandenh
I am buying a Fi bl series (not btl) 18" subwoofer. i am using a rockford fosgate t100.1bd amplifier on it, in a ported box.
I was wondering if i should go with the dual1 or the dual2.
my friend told me to go with the dual2 but i was not sure why...
Can anyone explain to me why i should pick either one in great detail for someone who is a general beginner at this stuff?
AWESOME... Hey do these measurements sound right?
width -30"
height -24"
depth-20"
port width-4"
port length-8"
wood thickness- .75"
BL18
DUAL 1 | DUAL 2
Fs: 33.2 Hz | 33.2 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Cms: 0.88mm/N | 0.88mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 181.0 l | 181.0 l
Spl: 94.1dB 1W/1m | 94.1dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft
jamie vandenh
jamie vandenh
charleston SC
jamie vandenh
