Which Sub Should I Get?!?!
alright! made up my mind finally! lol im getting the Sound Qubed HDS210. Should be perfect for what im looking for! ill get the Dual 4Ohm version so i can wire it to 2Ohm for 650W RMS. I dont think my 8 gauge power wire will handle 1000W RMS and i really don't want to re run 4 gauge power wire.
You need to be using 4ga atleast anyway!! It sounds like you're trying to take too many shortcuts...
no, i just cheaped out when i bought the wiring kit and had some left over 4 guage from the big 3 upgrade to use as ground for the amp.
In the big 3 upgrade, is it really necessary to fuse the alt+ to Batt+ wire? If so, what size fuse?
Ugh..... Ok will do. Any idea on the fuse for the alt?
Don't fuse on your alt. If that fuse ever pops you'll just burn you alternator out because it wont' see your battery anymore. Those wire runs are less than 1 foot in most cases, tighten them down and don't route them where they can be damaged. I try and run with the stock wires when I can, since they clearly aren't in danger when the car is moving, it's a safe routing scheme.
ok, last question. im using 4 gauge wire from alt to the battery and i know 4 gauge wire takes 125A fuse, however i only have a 80A fuse. would that be sufficient?
you guys dont think i can run this sub at 1000W RMS without damage?
HDS210
id figured since im installing 4 gauge, might as well just get the dual 2Ohm VC and wire it down to 1Ohm to run at 1000W RMS.
i mean that amp is rated at 1000W RMS, but i think ppl have clocked it at 950Wish RMS at 1Ohm. tat sub is rated at 1200W peak and 600RMS. i just dont want to risk damage to the sub if i have it turned up a lot to show off //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
After impedance rise you won't be putting to much power to it. Just make sure you aren't clipping it. Clipping kills subs quick.
Quadrider10
Quadrider10
Jersey
Quadrider10
