Which re more spl?
ry4n
9
tx
I know this is such a n00b question. I have limited space. I know the re8s and the 12xxx will have plenty of sq but which will have more spl?
six re8s and a hifonics 1000rms
or
12xxx and a kicker 1200rms
i know the 8s will have more cone space but the xxx is huge.
any opinions please
I don't know which would have more SPL, I haven't heard either and it would depend on the install. Can you wire 6 RE8s to a load that will work well with the Hifonics?
Yes I belevie it would be close to the ideal 1 ohm load
the SE has more SPL than the XXX if IIRC
Not sure where you got that. Perhaps you mean the SX.
The SE is no longer made, replaced by the SX. Someone recently did a test of the RE subs and the SX came out with slightly more SPL than did the XXX. The test used a 1000 watt amp, just about ideal for the SX, but definitely didn't get the XXX moving to its potential. But, now people are running around saying the SX has more output potential, when in fact its displacement is lower than the XXX.
In reality, the MT is the only sub RE currently makes with more output potential than their XXX line.
HC is no more...there's the RE, SE, SX, XXX, MT
Daily driving, with 1kw+, I'd put my money on the XXX being the loudest. SPL applications, MT...
If your burping, and that is all the SX will get louder than the XXX. I believe in Davids post he said the SX was louder in his application than mts. I know in his Street B car he uses SX's
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
602
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
752
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
907
ry4n
ry4n
tx
Qckrun
Decebal
    Jun 10, 2024
