Which RCAS to get?
The cdsp doesnt have an aux input and the aux on the dac is an output.
There is no reason it shouldn't work though. So I wouldnt worry.
Sent from my SGH-T999 using Tapatalk
the cdsp has two channels of rca input, I would use a 3.5 - rca converter and use that if i had too. either way I will probably do this so any of my friends who have an iphone can play music through my system, even though it wont be the best quality. that or hook up my factory radio to it in correlation to the digial input, you can have more than one input hooked up im reading and turn one off and one on with presets on the remote
Be sure to get the cdsp, not the minidsp.
Id do short usb and long coaxial
Just installed the cdsp, it sounds outstanding! it went well over what I was expecting I haven't even EQd anything yet all I have set are the x-overs and have reset my gains to the cdsp and it sound 10x better than my old eq'd lcq. Not only does it sound much better, there is absolutely 0 feedback, noise, crackling ect. and is slightly louder than it was before. I would recommend this setup to anyone who is going for sq.
along with this I also have my factory radio hooked up to the cdsp, I have it setup so when I go to preset 4 I can still listen to my radio, use my 3.5 aux or anything else with the factory radio.
Have you tried the android to spdif yet
yeah I did thats what sounds alot better, the factory in doesn't sound nearly as good. despite what people were saying on the forums I could only get the spdif to work via the app that was mentioned, although I don't mind it.
i believe the app lets you use the music thats on your phone so no worse for wear.
Brian235
Brian235
North Olmsted, Ohio
The Camry
