Which ones to get!!!!!
espguitarist91
yep
Well i need to make decision soon, very soon. Im going for SQL. Crutchfield has an awesome deal on infinity perfects right now. The 12's are 179.99 and the 10's are 149.99, but theyre both buy one get ine free. Cardomain has Infinity 1250's two for $150. I have 1600 watts @ 1 ohm and would be going sealed by the way. My options are these:
4 12" perfects-359.98, free shipping
4 10" perfects- 300, free shipping
4 12 1250w's- 300 + shipping
or 2 12" type R's ported- around 290 shipped, unauthorized
Thanks for any help or advice.
the 4 12" Infinity's
I knew it!
Well, would there be a noticable loss in output between the 10" and 12" perfects?
And do you think theyd be okay with ~400 watts? Ive heard theyre easy to burn up, but if used properly and in a sealed enclosure, it shouldnt be a problem, right?
Id like to keep it as cheap as possible, so the 10" perfects would be perfect, no pun intended. I just dont want to be disappointed and wouldve rather gone with the 12's.
Edit- Its a 1991 deville, so trunk space is plentiful:)
So its worth the $60 to get 12's? Well if i went with the 12's, i might have to do 4 cu. ft. net, before displacement and bracing. Would they be fine a little smaller than 1 cu. ft. each? Also, would they be okay with around 400 watts each if i take it easy on the gains?
Edit- Also i forgot to mention, the sealed reccomendation for the 12's is 1 cu. ft. and the ported reccomendation on the 10 is 1 cu. ft. also. So i could go with four 10's ported if 1 cu. ft. isnt too small for them. Im guessing that would be quite louder than four 12's sealed.
espguitarist91
yep
espguitarist91
bloomingdale IL
espguitarist91
