which one looks better on paper?
leonsv
**DIABLO**
tc1000 vs ss rli
both 8"
i noticed recently that although they share the same motor, they have different spec and are different subs....which is better? on paper? actual experience?
8" TC-1000 SVC
Qts 0.434
Qes 0.478
Qms 4.68
Fs 25hz
Res 4.25Ω
Ls 1.59mH
Lp 0.792mH
Rp 2.33Ω
Dia 160mm
Vas 17.9l
mms 98g
cms 316m/N
bl 12.9T*m
Spl 82.8dB
Rms 400 watts
xmax 24mm
ss rli 8"
Single 4
Qts: 0.217
Qes: 0.235
Qms: 2.798
Fs: 25.7 Hz
Re: 3.78
Ls: 2.022 mH
Lp: 3.859 mH
Rp: 3.786
Dia:
(% shift) 160 m
44.7 %
Vas: 23.44 L
Mms: 92.47 g
Cms: 412.8 u
Bl: 15.51 T*m
n0: 163.8 m
SPL: 84.14 dB
Sd: 0.020 m^2
RMS: 300 watts
Xmax: 18.3 mm
P.S each will have 358 rms and will be in a .5 sealed enclosure
thanx
TC-1000 any day.
I wouldn't throw the DD in a small sealed enclosure like you want.
leonsv
**DIABLO**
leonsv
phoenix, az
Immacomputer
