Which JL sub
tee
You know
586
BR
How the heck do you figure out which JL sub it is. All I can tell is that it is an older version because it has a big "JL" and has "JL AUDIO" under it on the cone. Other than that, it has JL Audio on it on the back. There is also a sticker with a bar code on it with the numbers: 07 FK793 94.
Got a picture front and back? That would help a ton.
See.. that's the thing. I can't get any pictures. I will try to describe it as best as I can. The subs are 10", SVC4. The sticker under the sub is missing, but I can still see it says JL Audio going around in a circle. The terminals are the female/male kinds, not the fancy pretty ones. The front looks just like this:
The 10w3 were DVC for versions 1 and 2. The W0 and W1 were SVC. If the backplate has a bumped out section in the center shaped like a cone, it's a W0. If the back plate is relatively flat with a 1/2" or so pole vent, it's a W1. The W1s were rated for 125W and won't really like much more than that. I ran mine with around 120 and it was right at its excursion limits in a sealed box.
tee
You know
tee
BR
helotaxi
