Which is the Better sub JL or Kicker Comp?
  • Thread starter Unregistered
  • Live activity
  • Replies 5
  • Views 2K
U
Unregistered
Guest
What's up to all?
A quick question for you all. I'm looking for 2 new subs to be set up on independent sealed boxes, the smallest possible. So far I've narrowed it down to 2 subs Kicker Comp 10" or JL Audio 10WOs both 125w rms each 8ohms for 4ohm load.
Which would be best for my amp Sony 2150gsx 760w:
Key Features:
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
stereo, bridged mono, or Tri-Way output
MOSFET power supply and output stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
line-level and speaker-level inputs
gold-plated connectors
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz
requires 8-gauge power and ground leads
I have 2 10" JL audio W3's and they kick ***, the bass is hard and tight and iM only pushin em both by a bridged 300 watt pioneer amp, KIcker makes good products I heard some crazy systems using kicker subs, but I love my W3's. Whatever you choose you'll get some good bass. Peace man
i would probably go wit da kicker subs, the jl subs will last a long time but i heard that the kicker compsreally kick ***. if u go wit any jl at all, i would go wit w3's.
I'd say the W3's are very nice I own two twelve inches. If you want to go with Kicker don't go with just the Kicker Comps get the Kicker Comp VR's. They are so much louder than just the comps and they are better sounding as well.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Guest
JL Playa RU
vegang
vegang
