Which is the Better sub JL or Kicker Comp?
  • Thread starter Unregistered
  • Start date
  • Replies 9
  • Views 1K
U
Unregistered
Guest
What's up to all?
A quick question for you all. I'm looking for 2 new subs to be set up on independent sealed boxes, the smallest possible. So far I've narrowed it down to 2 subs Kicker Comp 10" or JL Audio 10WOs both 125w rms each 8ohms for 4ohm load.
Which would be best for my amp Sony 2150gsx 760w:
Key Features:
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
stereo, bridged mono, or Tri-Way output
MOSFET power supply and output stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
line-level and speaker-level inputs
gold-plated connectors
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz
requires 8-gauge power and ground leads
Since you are looking for a relatively small enclosure, I would reccomend the JL firstly. They have always had better luck in the smaller enclosures. Should provide decent SQ and boom all at once.
take it easy,
-zane
a friend of mine has 4 wo 10s in a single cab chevy one of the hardest hitting systems i ever heard coarse he is the expert i no so it might be his awsome install.
although kicker has good speakers there subs aren't all that good i would good with the JL's cause if you diden't you woulden't have any fun.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i ment that the comps aren't that good but my favirate subs are the kicker baric's (sqaures) i think they are the best. god how could i do that. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
smaller the box the better the jl will out perform the kicker....if you have about 2.5-3.5 cft the kickers get rich and boomy sounding (thats the kicker draw) but its sorta sloppy bass in my opinion
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
797
Guest
audiolife
    May 24, 2024
