Which is the Better sub JL or Kicker Comp?
  • Thread starter Unregistered
  • Live activity
  • Replies 9
  • Views 1K
U
Unregistered
Guest
What's up to all?
A quick question for you all. I'm looking for 2 new subs to be set up on independent sealed boxes, the smallest possible. So far I've narrowed it down to 2 subs Kicker Comp 10" or JL Audio 10WOs both 125w rms each 8ohms for 4ohm load.
Which would be best for my amp Sony 2150gsx 760w:
Key Features:
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
stereo, bridged mono, or Tri-Way output
MOSFET power supply and output stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
line-level and speaker-level inputs
gold-plated connectors
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz
requires 8-gauge power and ground leads
Since you are looking for a relatively small enclosure, I would reccomend the JL firstly. They have always had better luck in the smaller enclosures. Should provide decent SQ and boom all at once.
take it easy,
-zane
a friend of mine has 4 wo 10s in a single cab chevy one of the hardest hitting systems i ever heard coarse he is the expert i no so it might be his awsome install.
although kicker has good speakers there subs aren't all that good i would good with the JL's cause if you diden't you woulden't have any fun.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i ment that the comps aren't that good but my favirate subs are the kicker baric's (sqaures) i think they are the best. god how could i do that. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
smaller the box the better the jl will out perform the kicker....if you have about 2.5-3.5 cft the kickers get rich and boomy sounding (thats the kicker draw) but its sorta sloppy bass in my opinion
Guest
audiolife
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
