Which is better (massive audio)
cleansoundzz
Which is the better amp the Massive Audio N4 or D3600?
The specs for the D3600 are:
•Input Sensitivity Low Level: 120mVrms ~ 5.0 Vrms
•Parametric Bass Boost EQ from 30Hz - 80Hz
•All Models Linkable with Single rca for easy upgrade
•Short Circuit, Thermal, Reverse Voltage and Over Voltage Protection
•N-Channel Circuitry for High-Efficiency
•Variable Lowpass: 40 – 200 Hz/ 18dB
•Heavy Duty power Supply
•Illuminated Logo
•Heavy Duty Aluminum Heat Sink
•Designed and Engineered in U.S.A.
•Proprietary "Bass Kompressor" Circuitry provides Low-Frequency Enhancement
•Extreme power in a Small Footprint
•High Efficiency Class "D" Design
Weight 15 Pounds
RMS Power 1800w x 1
PEAK Power 3600w x 1
RMS @ 2 Ohms 950w x 1
Bridged RMS n/a
Min Impedance 1 ohm
Min ohm Bridged n/a
THD
S/N 70 dB*
Max Voltage 15v
Max rca Voltage 5v
Freq. Response 10Hz - 180Hz
Dimensions 14.8 (in) x 6.5 (in) x 2.1 (in)
The specs for the N4 are:
•Extreme Power in a Small Footprint
•Ultimate Mounting Flexibility (Stackable, Line Array & Side Mount)
•Mil Spec Double Sided PCB with SMD Parts
•Built-in Noise Reduction Circuitry
•Full Mosfet with High Grade Switching Devices
•Next Generation Advanced Protection Circuitry
•World Wide Standard Compliant (RoHS, E8, CEA-2006 & CE)
•1 Ohm Stable Design
•12/6/0 +dB Adjustable Bass Boost
•Micro Circuit Topology
Weight 12 Pounds
RMS Power
2000w x 1
PEAK Power
4000w x 1
RMS @ 2 Ohms
1000w x 1
Bridged RMS
n/a
Min Impedance
1 Ohm
Min Ohm Bridged
n/a
THD
S/N 100 dB
Max Voltage 15v
Max RCA Voltage 5v
Freq. Responce 10Hz - 220Hz
Dimensions 13.4 (in) x 5.5 (in) x 2.1 (in)
Bass Remote Optional (DBR Gain Remote Knob)
It seems that the D block series has been around longer. I am not for sure though.
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
Mike Mccabe
