which headunit to go with??
cyoung88
Ohio
alright i need a new headunit so im stuck on what to get. I want it to sound amazing and not skip with my bass. also i want the color to glow blue. im thinking about going with eclipse, pioneer, or jvc., also want it to have a pause button. im wanting to spend no more than 300, maybe 350. what do you suggest??
405
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
991
cyoung88
cyoung88
Ohio
kottonmouthking
    May 16, 2024
    May 16, 2024
