which box is generally louder?
Different suv's and different setups like different firing positions. There really isn't an exact answer. But, for the most part you'll see ports firing back towards the rear.
The most universal would have to be subs up and port back, though some variations can/will yield higher performance.
But if you want to stick to one proven design rather than trying all different kinds of boxes, subs up and ports back is the way to go.
I'd agree sub up port back usually works best, but Ive found sub back port back at least 6" from the back works well too but this could be very vehicle dependent. I would try both and see what you like more if you can, if not just go sub up port back.
I wouldn't think there would be enough volume for air to move external to the port if it faced back in and extended cab truck. I would give that a NO and say port up sub up would most likely be your best bet.
In my blazer subs up port back. In my xcab s10 subs up port up. That was what worked best in my setups. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
In my RAV4....definitely sub back (I've had sub back port back and sub back port up -- doesn't seem to matter)...
Sub up port back still hit good but not quite as good...
Actually since I have an EPIC-150 I just used that to see the difference...sub back was consistently 1 db louder...
wcarson8911
wcarson8911
Little Rock, AR
sku
