Which Amps To Choose
tito211
I really need to get a new amp for my new sound system. So far ive narrowed things down to a Kicker zx 1500.1 and a Rockford Fosgate 1001bd. Ive read that both are underrated and put out good wattage. My sub is a fi audio single 15"bl, which has a rms of 1000. So which amps do u think will best handle the job.
thanks
x2 psycho depending on what vc config ur sub is that should be the deciding factor really, obviously both are very impressive, if you need a 1ohm load go with the rockford and if you have a 2ohm load go with the kicker. but if your looking for the most wattage the kicker is going to give you a couple hundred more, but you really dont need it since the subs rms is 1000 and youll be runing around 1500-1800....
tito211
tito211
atlanta
mike dressure
