Which Amp should i buy
how many watts @ how many ohms should i be looking for in an amp , i have heard MTX amps are good for kicker subs the subs are (2) 12" CompVRs with 400W RMS and 800W peak Single 4-ohm load at terminal cup
i really dont know much power i need to get good pounding bass you can hear down the block
please help
EDIT : when you say that the kicker box setup is a 2-ohm load what does that mean ? can this be true even if my subs are 4 ohm ?
if i have (2) 12" 4-ohm Dual Voice Coil CompVRs in the kicker box can the overall box still run @ 2-ohms? or would the 2 subs need 2 be both 2-ohm subs??
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
ok so i went to the kicker website and downloaded the guide for my sub box
and this is what i found:
does this mean i can run my amp @ 2 ohms because it says my box will produce a 2-ohm load overall????
Prizm
Prizm
canada
Prizm
