Which amp is good enough?
nyclancer
This is my first post as a member.....hello everyone.
Question...
I plan on purchasing 2 Alpine Type-R's. I've heard good things about thair sql. I Also plan on running 2 amps, but the question is... Which amp should I get? I plan on getting 2. Reasonably priced would be ideal. Which amps work best with the Alpine Type-R's?
Thanks, all your input will be greatly apperciated.
First off, welcome //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Secondly, why do you want to run separate amps? It's just going to be more of a hassle.
I'd look into a JBL 600.1, or, if you insist on 2 separate amps, 2 JBL 300.1's. They can be found on http://www.ikesound.com for relativley cheap, shipping included.
Originally posted by nyclancer should i get a capacitor? right now with my 300x1 amp my lights dim...
Don't waste money on a capacitor. If it is that bad then get your alternator rebuilt. Do you know what size your stock one is?
EDIT: Dammit, Jmac.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it might just be a nasty inefficient amp. look for class d mono, like jbl.
Also make sure your hooked up using 4guage directly to battery with appropriate fuse, not to any wire under the dash.
nyclancer
nyclancer
New York
lephatrabbit454
michigan born
    May 14, 2026
michigan born
    May 14, 2026
