where to put deadener
well the edead group buy is still going on.. ends tonight at midnight though, go look for it in the classifieds section. good stuff that edead.
and for applications.. wherever you can fit it man.. if you wanna make your flatulence quieter.. insert between your buttcheeks as close to your anus as possible.
alright so if you put it on the door then wouldn't the deadener cover up the little holes where those cheap plastic connectors connect the door panel to the actual door. Would you just have to punch a hole through deadener i guess.
littlebuddy34
littlebuddy34
woodstock, ga
littlebuddy34
michigan born
    May 14, 2026
michigan born
    May 14, 2026
