Where to place the amp?
whwatts
I have a 2003 GMC Sonoma Extended Cab that I built a nice little box for and I need to hook up the amp. I had originally planned on putting it under the seat, but it won't fit. A friend said to take the back off the jump seat off, but I am hesitant to do that as it tends to get quite a bit of use. I am thinking about just drilling holes through the back of the truck, mounting a piece of wood to it and the amp to to the wood, but I think it would be somewhat conspicuous. Any other (inexpensive) ideas as to where I can put the amp?
Thanks.
no roof //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif amps can usually not be mounted inverted. but basically anywhere you can fit it is fine, don't mount it on bare metal. Sub box can work, but sometimes vibrations arent good for it and can loosen components inside ofit.
whwatts
whwatts
Fairfield, Ca
southprk
