Headunit
mr_kebo
All the headunit needs to come on is the +12volt and a ground? Well i just got my new cd player in and hooked up the +12, ground and the Illumination wire. And nothing. Checked all fuse, they were good so i busted out the mult. meter and tested the +12v and im getting 14.1volts. So i try and new ground spot and still nothing. I even go as far as running a new +12 and ground from the battery and nothing. The fuse in the back of the headunit is still good. Is it safe to say the headunit is a dud? I want to make sure and test everything before i call for an RA #.
seriously..//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Yellow= constant 12v+, Red= switched/ignition 12v+, Black= ground..
dont forget the speaker wires and the rem turn on wire!!
Yep.
On every single headunit I have it's the same way.
Actually that's backwards
Umm, what???
actually thats not...
Winnar!
You need to connect 3 wires in order to turn it on.
A red one, a yellow one, and a black one.
Yea thats what i did yellow +12 constant Red +12 switched and black ground. Thats what i had hooked up when i went back outside after the rain stopped. Not sure why i kept calling it the illumination wire :/
mr_kebo
mr_kebo
Huntsville, AL
mr_kebo
