Where to fuse power cables?
Thanks. What fuses would I use if I was driving 2 amps off a dist. box: a 120 watt Sony amp for subs and an Alpine MRV-345 (75 w x 4) amp for front and rear.
Just wondering what fuses to put in dist. box.
What if I wire the power to one amp, from the 12Vout of that amp I wire another amp, do I need any extra fuses in there somewhere.
I'll be using 8 gauge power wire throughout tho
DO NOT wire an amp like that. Not only is it dangerous.. also pretty ghetto. Buy a distro block and fuse each line at 50A.
It's not dangerous, but it is a bit ghetto. As long as the primary wire is large enough to support both amps it's exactly the same thing as a distribution block. Wouldn't be very practical if you're using very thick wire, but electrically there's nothing wrong with it.
I'm only using 8g throughout...should be good right? 400 watts @ 4ohm for the sub, 50 watts X 2 @ 4 ohm for speakers.
kingsxman
Noob in training
kingsxman
Minneapolis
n2audio
