where to find 8g distro blocks??
nas786
I just wanna split my 8g power wire to 2 different amps, and then connect the 8g grounds back together, but I can't find any 8g in to 8g out fused/non-fused blocks. Anyone know where to look?
Also, can I possibly use let's say a 4g in to 4 8g out, and just wire up the 8g ones....?? It seems like it might be bad, but just seeing if this is an option.
no fuse in it, check around that website and maybe they have something to offer.
i always thought you would have to fuse each output seperately though:eyebrow:
if ur mono amp is rated at 80amps and ur speaker amp is only 20amp and your gonna find a distro block that has a built-in fuse holder...idk how i would go about that.
ive got a few rockford fosgate non fused (1) 4ga input in (4) 8 ga outputs
I have two of them laying around
pmme if you want em for stupid cheap as theya re just sitting in my tool chest
I also have a few (1) 1/0 input to (3) 4 ga output non fused lightining audio distro blocks also
don't you need something bigger than 8gauge if it is used an an input because the draw of (2)8 gauges already?
I'm not sure, actually I kind of thought this before, but a couple people said it shouldn't be a big deal. I already have 8g wire, but if its necessary then i'll buy some 4g....anyone know?
to me it makes sense that there are two 8 gauge drawing high current from the single 8 gauge. correct me if I am wrong but the single input won't deliver enough to power the amps? im still looking to see if thats true, but just to be safe, you know?
nas786
nas786
central cali
dleccord
Mike Mccabe
