helotaxi
Kilroy was Here
^^^There are 4 and only 4 specs that determine how an amp will sound below clipping.
1)Distortion: If you can't hear it its low enough. If the distortion measurements are the BAL there is no difference from this spec.
2)S/N: If it's inaudible then nothing here as well.
3)Frequency response: If an amp sounds "warm" it has an issue in this spec. An amp should not "sound" anything. It's job is to increase the voltage and current of a signal without altering it. If it is rolling off or has non linearities within the frequency range it is being used in, then it isn't a good amp.
4)Power: Power makes the world go 'round. Psychoacoustics tell us that louder sounds better. Extra power also allows the system to be more dynamic. Even if you only ever use around 50w having 200 on tap is only going to help. Effortless dynamics are created by having headroom.
If those 4 specs are inaudibly different, there is not a person alive who can distinguish the difference between two amps. For any amp worth owning (and I dont hardly limit this to "high-end" brands, I use old Orion and Phoenix Gold, hardly "high-end") the only spec that needs to be considered is #4 where more or the money is better. Beyond that you're paying for intangibles: reputation, the boost to your ego, reliability (which is almost a wash with solid state electronics above budget grade anyway), and customer service (which with reliable electronics isn't often needed). Spend you money however you want, but if you think spending a ton on amps is going to give you verifiably better sound, think again.
