Where Should I Set the Crossovers At?
Jer510
Slap Addict
I listen to mainly rap and I need some help with adjusting the settings on my deck and amp.
On my deck, the settings are the following:
- sub level: 15
- bass: 0
- bass bandwidth: 1
- bass freq: 80hz
- treble: 5
- treble freq: 12.5khz
- balance: 0
- fade: 0
- loudness: on
- sub system: 2
- hpf: off
Should I keep the bass frequency at 80hz and should I keep the HPF off? Or should I change those settings.
And where should the gain adjustments be on my amp and epicenter? Should they match the settings on the headunit? Please help. Thanks..
I would say the HPF should be on and for your gain you have two ways of doing it first way is go of what alpine says ur preout voltage is and set it to that but the best way it to check it with a dmm
Jer510
Slap Addict
Jer510
Oakland, CA
93dakota
Mike Mccabe
