Where is the Parking Brake Switch?
I am hooking this up for a friend, I don't feel like buying or rigging up a relay. I am using a pioneer head unit by the way. Does anyone know where the brake switch is?
last i checked there is not buying or rigging involved, it's just connecting it to a ground.
you cant just ground pioneers. have to be on relays
---------- Post added at 06:21 PM ---------- Previous post was at 06:21 PM ----------
or switch\
He is correct you can not just ground Pioneers. Has anyone ever hooked this up the proper way? :p
yes i have and if it is a avh-????dvd it is easily bypassed (not just grounded) but switched ground .......can be done with relay or just a simple toggle switch (one end to ground and other to parking brake lead)
the avic (navigation units) like the Z130bt or Z1140 bh or X930bt or X940bh require a moving a pin in a/v harness and grounding it along with the parking brake wire.
but to answer the Question you asked the parking brake wire is located @ the lever under the center console / while there is nothing published on the wire itself , it will be very easy to locate,, on the base of the lever there will be a wire (connected to a pin ) that goes to ground when the brake is engaged. (it must go to ground) just use that and "viola'" you are hooked up "legal"
good luck
yes i have and if it is a avh-????dvd it is easily bypassed (not just grounded) but switched ground .......can be done with relay or just a simple toggle switch (one end to ground and other to parking brake lead)the avic (navigation units) like the Z130bt or Z1140 bh or X930bt or X940bh require a moving a pin in a/v harness and grounding it along with the parking brake wire.
good luck
Haha finally an answer that I was looking for! Not to dis anyone else but this is what I was needing. And yes it is a AVH-P2300DVD. Since this is not my install in my car I want this done correctly so I am not going to bypass it with a relay, or toggle switch.
Okay so you said it is a "lever" under center console. I am a bit confused what lever you are referring to, and where I should be seeing the wire.
the parking brake is a lever in the center console (you pull it up to engage)
the should be a signal wire @ the base ( this should go to ground when engaged)
Patthehat033
Patthehat033
Missouri
Patthehat033
