Whats your thoughts on this amp
TKCARAUDIO
I have a friend that has a Fusion Encounter 1 channel high efficiency 1 ohm stable FE-300D Amp
here is a link to a pic
http://discountpowerparts.com/catalog/popup_image.php?pID=1341
here is specs I have found on it
FE-300D - Fusion FE-300D 1 Channel D-Class Linkable Amplifier, 200 WRMS per channel @ 4 ohms at 14.4V
FE-300D
CEA 2006 Rated
Want more Power? FUSION D-Class technology is able to produce up to 5 times the power of a single amplifier when linked. All FUSION D-Class Amplifiers will accpet 18 volts DVC and are 1 Ohm Stable.
1 ohm stable / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
Compatible with FUSION bass control remote
Product Specifications
Bandwidth 10Hz – 250Hz
Signal to Noise >95dB
Fuse Rating 2x 20A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz – 600Hz @ 12 dB / octave
Variable Bass Boost 0 - + 12dB @ 45Hz
Variable Sub Sonic Filter 10 Hz – 55Hz
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.06%
Dimensions D 57.5mm L 340mm H 220mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
150 WRMS per channel @ 4 ohms and ≤ 1% THD+N
270WRMS per channel @ 2 ohms and ≤ 1% THD+N
360 WRMS bridged channels @ 4 ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
200 WRMS per channel @ 4 ohms and ≤ 1% THD+N
350 WRMS per channel @ 2 ohms and ≤ 1% THD+N
475 WRMS bridged channels @ 4 ohms and ≤ 1% THD+N
Linked Power Ratings @14.4DVC
800 Watts RMS Linked @ 4 Ohms
1000 Watts RMS Linked @ 2 Ohms
on close out it retails for $290.03 here is a link to where I found info
http://discountpowerparts.com/catalog/product_info.php?products_id=1341
I am curious of what you guys think about it. And also what you guys think it would be worth. He has offered it to me for $75 but Im not sure if I would want to give that for it...
Tell me what you guys think... Also would it be a good mono block amp to run 2 Kicker CVR 12s
fusion is terrible i think BBuy or CCity sells them
WOW are you serious....their still selling stuff..i gots to go get me some fusion from them...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Get with the times CCity has been out of business...check their website.
duh they went out about 2-3 months ago I know this I bought all the glass cases they had for $25 each. they are right around the corner from 1 of my shops. i was saying that the brand was a store brand for 1 of those 2 bigbox stores.
pay attention and next time since it is so insignificant of an issue just shut the **** up. does it really matter if they are closed or not? did your statement have any bearing at all on the OP's ? ok then idiot nuff said.
duh they went out about 2-3 months ago I know this I bought all the glass cases they had for $25 each. they are right around the corner from 1 of my shops. i was saying that the brand was a store brand for 1 of those 2 bigbox stores.pay attention and next time since it is so insignificant of an issue just shut the **** up. does it really matter if they are closed or not? did your statement have any bearing at all on the OP's ? ok then idiot nuff said.
dang wish I would have new how cheap there cases was lol. i would have bought them all.
TKCARAUDIO
TKCARAUDIO
Chillicothe/Circleville Ohio
TKCARAUDIO
