What's your opinion?
What do believe would sound better with 600 dollars should get a head unit an speakers for the doors an the trunk, or try an get all speakers plus a subwoofer an amp in the trunk on the sam budget. This will be imside a 06 hyundai accent if you wanted to know
skar is running a great deal 2 vvx 12's in a custom box for 370. then get a cheap amp (apsm 1300, brz 1200, mb quart 1500) and put in some co axials.
Ok, nice talking with you on the phone.. Listen, i do want to say, your only 16, and there is plenty of time to grow into things, and improve on what you have to start out with.. And as i told you on the phone, you listening may change, you will start to understand in this field all the qualities that audio does and does not have.. I also have a 15 yr. old, than is about to start driving and etc.. So i can understand a young man wanting some nice sounds in the car, etc.. But i also think driving and learning that whole responsibility is #1... Dont get distracted and be safe.. That being said, i can also understand a young man wanting to get his car sounding GOOD now, and not waiting... Here is what i have put together for you, for your thoughts..
And guys on here feel free to take a look at this equipment.. I think it is more than FAIR, and i doubt anyone can touch this, and its good stuff, not junk, but wont be your top of the line like the AudioSystem stuff i carry..... AND you can be on the road to jammin... And my attempt to help a young man out in his quest...
This is ALL NEW IN THE BOX STUFF, just older model stuff or discontinued i have at the warehouse..
Panasonic CQ-C8413U head unit
first all, no usb, but has rear Aux, and is ipod capable.. More important is its a good sq deck, and was quite high a few years ago..
Maximum Output Power: 50W x 4
Power Output: 18W RMS x 4
MOS-FET Output Stage
SRS WOW
SQ7 Sound Quality
High & Low Pass Filters (crossover)
SBC-SW (Super Bass Controlled Subwoofer)
Dual (5V/60 ohms) Pre-Amp Outputs
Subwoofer Output (Level/Impedance): 5V/60 ohms
iPod Ready: Panasonic CA-DC300U is required and sold separately. The Panasonic CY-EM100U is also required if you wish to use more than one Panasonic external accessories such as Bluetooth, CD Changer and/or XM/SIRIUS satellite radio.
Satellite Radio Ready (Subscription, adaptors and tuner required. Panasonic CY-EM100U adaptor and one of the following tuners: Sirius SIR-PAN1 or XMD1000 and XMDPAN100.
Bluetooth Handsfree Cell phone Ready: You can connect the optional Bluetooth hands-free kit with the use of Panasonic CY-BT100U and Panasonic CY-EM100U
Expansion Module Ready
MP3/WMA Playback
CD-R/CD-RW Playback
Frequency Response (±1dB): 20Hz - 20kHz
S/N Ratio: 96dB
THD (1kHz): 0.01%
Channel Separation (1kHz): 75dB
CD Changer Control
4096-Color OEL Display
Customizable High Definition 3D Dot Matrix Display
Large Rotary Knob
Super Bright Display with Dimmer
Blue Button Illumination Color
Fully Motorized Front Panel
Open Face CD Access
Removable Faceplate
Wireless Remote Control
2 - MTX T5512-04 woofers
12" Single 4 Ohm Thunder 5500 Series Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
Impedance: Single 4 ohm
Mica-filled polypropylene cone woofer
Rubber surround
Heavy duty chrome push terminals for easy speaker wire connection
Tinsel leads woven in the spider
Spider Plateau Venting technology which ensures a cooler, more reliable subwoofer
1.75" Voice coil
70oz. Magnet structure
Frequency response: 29-150 Hz
Sensitivity: 90 dB
1 MTX 2301 mono amp test sheet does 401 (perfect for woofers in ported enclosure)
Thunder TA Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
Max power output: 300 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
Thermal and short LED indicators
Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
Adaptive Class D Technology: With MTX innovative approach, the amplifier’s switching energy is constantly changing and is moved away from FM radio frequency ranges as the amplifier’s load and output increases.
Thermal and short protection
StreetWires Connectors
Xtant Technologies Cooling (XTC) thermal-regulated, turbo-charged intercooler
Variable low-pass filter (at 80 or 120 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Dimensions: 12-11/16"L x 9-5/8"W x 2-1/2"H
MTX 3404 4ch. amp
MTX Thunder 4-channel amplifier
RMS Power Rating:
50 watts x 4 @ 4 Ohms
100 watts x 4 @ 2 Ohms
200 watts x 2 @ 4 Ohms (Bridged)
Wired EBC Remote Subwoofer Bass Level Control Included
Fan cooling with XTC thermal regulation technology
Prizm EFX customizable lighting accents
Selectable high-/low-pass filter (85 Hz at 12 dB per octave high-pass, and 24 dB per octave low-pass)
MOSFET power supply and output stages
CEA-2006 compliant
Speaker-level inputs with Smart Engage
Preamp inputs and outputs
Dimensions: 12-11/16" L x 9-5/8" W x 2-1/2" H
Massive Audio VK6 component speakers
Weight 6.50 Pounds
Speaker Size 6.5"
Tweeter 20mm Silk Dome Tweeter
Cone Poly Mica
Sensitivity 88dB (SPL@1w)
Frequency 60Hz - 20Khz
RMS Power 5-60 watts
Peak Power 250 watts
Impedance 4 Ohm
Crossover 12 dB External
Basket Heavy Gauge Steel
Depth 2.4"
Clarion 5x7 coax speakers dont remember model, but they are just rear fill, and im giving them to you free //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
StreetWires PSK04B 4ga. amp kit
4-gauge amplifier wiring kit with power and ground connections
18 feet of 4-gauge blue power cable with nickel-plated ring terminal
3 feet of 4-gauge silver grounding cable with nickel-plated ring terminal
in-line fuse holder and 100-amp AFS fuse
16 feet of 18-gauge blue remote turn-on wire
assorted connectors, spade terminals, and wire ties
9 wire to complete 4ch. installation approx. 17' should do..
3 pairs of RCA to complete both amp connections
ALL of this for $600 even cash money... Add it up, i think most here will see the value in this..
You now have some food for thought..
I would go wigh what tallc is saying. Thats a pretty nice system.
Tallc what shop are at? Im here in north richland hills and might come check out your shop this week looking for an 8" sub that im going to put in a fiberglass rear center console for my jetta.
Madison75
Madison75
DFW, Texas
2007rustanggt
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
