What's wrong?????
luvdatmusik
wassup every 1:)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)!!! I know its been a while since Ive been here, but I did an install yesterday ( 2007 dodge charger) 2 amps, 6x9's, drycell, & isolator. My question is..... yesterday evrything was fine, but now the owner called and said that 1 of the amps stays on. Now both amps r connected to the same remote & grnd, but I still can't figure out y. Could n e 1 lend sum advise?????//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
one of them is getting constant voltage supply somewhere in the wiring....
could be anywhere behind the headunit, whereever you were wiring.. id recheck everything and see whats going on for yourself.
I did check, but it still is confusing the hell out of me. Ok let me xplain..... From the main batt - fuse-isolator-dry cell- capacitor-fuse block - amps. Now the amp controllin the subs is the one thats stays on. It looks like I got 2 start all over
maybe one of the + wires on the amp is touching the remote terminal?
but if both amps are connected to the same remote wire and only one is turning on... i dunno. that makes no sence. plug another amp on there in place of the problem amp and see if its still doing it.
x2 seems weird though
luvdatmusik
luvdatmusik
Chi-Town
bass-aholic
