kryptek213
hello people, past few weeks my amp has been cutting off and wont play at all. i have my amp tuned up right and checked my wiring and ground is perfect. noting is wrong with my sub woofer also. i notice the fuse that runs through the positive wire has water stuck on the clear casing and one end of the fuse is very little rust and some brown stuff in the inside and everything else is perfect the pin is not broken at all. i believe the amp doesnt overheat all. when the volume is up the power light goes off and the protection is off also. the hifonics logo is dims down a lot. sometimes get it working when i use a multi meter and it creates a spark and the amp turns on(which is really weird). after a while it cuts off(completely turns off no green or red light) for 2 second and then turns on again. again after a while it completely shuts off for couple of days if i am lucky ill be able to get it on by using the multimeter. last time it turned on i measured the voltage and it read 11.86v. what is wrong with my amp? i have hifonics hfi 1000.1d and one alpine type r 15. thank you
